I have a fusion 360 custom post processor that I have been using on my novaturn for sometime.
It can be found here:
https://github.com/dubstar-04/FusionDenfordPost
Please use at your own risk and always check the code before running on a machine. The post processor outputs comments in the code if there is an issue I have come across before.
If you choose to use it and find an issue please add a bug report to the git repo and I will update the code.
Thanks,
Dan
Thanks for sharing Dan,
I'll be using it fairly soon, I recently lost my hacked post during a Fusion 360 update so hopefully you've got something a little more robust than mine was. Threading caused me the most headaches!
Many Thanks
Barry M
Many Thanks
Barry M
dubstar_04 wrote: ↑Sat 18 May , 2019 7:34 am I have a fusion 360 custom post processor that I have been using on my novaturn for sometime.
Thanks,
Dan
Hi Dan,
Just tried to post some old files and I'm getting this error
Have raised an issue in the git, hopefully you can help as my code-fu is very poor!!
Many thanks
Barry M
Error: Failed to evaluate post configuration.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, June 26, 2019 10:28:19 PM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Error: SyntaxError: missing = in XML attribute
Error at line: 7
Failed while processing global script.
Error: Syntax error: Missing end of literal at line 268.
Many thanks
Barry M
Error at line: 7
