Does anyone have a controller card for a TRIAC VMC Mill for sale? The card detail is:-
1990 Optimised Control LTD D281 Issue 5. The Eprom shows esMint 3.28.
The card has a serial comms fault due to corrosion around the battery.
I would even consider a faulty card without similar damage, so I can trace the pcb print.
Robert
Mint Controller Card wanted
- Hardware/Software: Triac VMC (missing controller)
Re: Mint Controller Card wanted
The said Mint controller card is no longer required. I have managed to repair the board.
I'm now an X-Spurt at Mint RS232 comms faults.....ho ho
Robert
Robert
Glad you got sorted, bet you are happy you sorted it
Yep thanks. Now the learning begins and the search for the right tooling....
Rob
Rob
- CNC Apprentice
- Hardware/Software: Triac PC (1998, easychange), Mach4, Fusion 360.
NovaTurn NS, VR Turning, Fusion 360
robertpearce4 wrote:Yep thanks. Now the learning begins and the search for the right tooling....
Rob
Check out my eBay for quick change tooling:
https://rover.ebay.com/rover/0/0/0?mpre ... 3182871922
