Hi all,
I am just running my first program on my new triac using VR milling 2. My problem is the machine decelerates after each line of code and comes to a stop... Then accels to the next line resulting in a jerky motion. Is there a setting I am missing in VR milling 2 to set this to constant velocity?
Any help is appreciated!
So doing a little more reading it sounds like data starvation. I am going to check the baud rate settings... Does anybody have the recommended settings for VR milling 2? Baud rate, stop bits, polling delay? Any other suggestions? I will also try a new cable though I wouldn't think it would be the problem?
OK I figured it out. For those who may find this later there is a "turbo" mode that needs to be enabled in the auto run. Why it is not enabled from the beginning I don't know.
The Turbo button does now default to being on. Not sure which version of VRMilling it was changed but you can download the latest version from the Denford website.
Thanks that is a good idea. Just looked at the version I am running and it is 2.14... So a little out of date. I will give it a shot!
