Problem with transfer to new PC
My Triac (excellent machine) runs on Mach 3. I have transfered Mach 3 to a different PC- the old one is a bit unreliable. All settings and options have transfered correctly and programs will run except that the spindle won't turn. Going back to the old PC (using same parallel cable) fixes the problem, spindle runs fine.
With the new PC, I can hear a relay click when I press the spindle button, but that's all.
I can't see any difference at all in the various configuration settings, so what have I missed?
Thanks!
Richard
Re: Problem with transfer to new PC
go into the bios and set the parallel port settings to EPP
angel-tech wrote:go into the bios and set the parallel port settings to EPP
Thanks Tom, that did it.
Richard
