Mint 3.28
mike2424
Hardware/Software: cyclone tu150e /fanuc
Mint 3.28
Post by mike2424 » Thu 19 Sep , 2019 17:12 pm
Maybe a dumb question but my motion controller card have some corrosion and I was able to find on eBay 2 cards that are in much better shape for 50 bucks each and they are the same as far as they are D281 issue 5, the difference in the boards that I can see is the eprom chip which I can swap, but the clock speed gizmo is 12 and not 16 . Can I just swap that ? Also is there a eprom upgrade chip or does it have to be 3.28 v1.6/S-JD5 ? Thanks for any help his matter. mike
Re: Mint 3.28
Post by Martin » Fri 20 Sep , 2019 7:34 am
The clock speed should not effect anything.
Depending on what software you have depends on the Eprom. its will be best to use the original Eprom.
