Mint Controller Card wanted
robertpearce4
Hardware/Software: Triac VMC (missing controller)
Post by robertpearce4 » Sat 11 Aug , 2018 8:57 am
Does anyone have a controller card for a TRIAC VMC Mill for sale? The card detail is:-
1990 Optimised Control LTD D281 Issue 5. The Eprom shows esMint 3.28.
The card has a serial comms fault due to corrosion around the battery.
I would even consider a faulty card without similar damage, so I can trace the pcb print.
Robert
robertpearce4
Re: Mint Controller Card wanted
Post by robertpearce4 » Fri 17 Aug , 2018 15:18 pm
The said Mint controller card is no longer required. I have managed to repair the board.
I'm now an X-Spurt at Mint RS232 comms faults.....ho ho
Robert
TDIPower
Post by TDIPower » Fri 17 Aug , 2018 20:55 pm
Glad you got sorted, bet you are happy you sorted it
robertpearce4
Post by robertpearce4 » Wed 05 Sep , 2018 13:47 pm
Yep thanks. Now the learning begins and the search for the right tooling....
Rob
dubstar_04
Hardware/Software: Triac PC (1998, easychange), Mach4, Fusion 360.
NovaTurn NS, VR Turning, Fusion 360
Post by dubstar_04 » Sun 16 Sep , 2018 16:15 pm
robertpearce4 wrote:Yep thanks. Now the learning begins and the search for the right tooling....
Rob
Check out my eBay for quick change tooling:
https://rover.ebay.com/rover/0/0/0?mpre ... 3182871922
