as in the title i need one of the eight grippers and it's holder for a triac atc. That's the flexible gripper and the half round mount that makes up the tool holder in the carousel.
Bit of a long shot but you never know.
Triac atc carousel tool clamp gripper wanted
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
- bradders
Re: Triac atc carousel tool clamp gripper wanted
MCV2/711 Tool Holder Roller - 2 required per tool holder - £18.00 each
TR3/728A Tool Holder Spring - 1 required per tool holder - £8.00 each
These prices are ex P&P and VAT
4 Quatros
3 Oracs
2 Easiturn atc
and i need the ally block that holds the tool holder spring in place.
Have added some detailed drawings of the triac tool carousel
viewtopic.php?f=47&t=3812
- CNC Apprentice
- Hardware/Software: 2001 Cyclone with toolchanger and Fanuc 21i control
Serial number - H00913.
Serial number - 70826B.
Are there any of the springs still available?
The spring is still used on the current VMC1300 Toolchanger as a VMC/0721 The price is now £11.50 plus Vat
The old spring had to be drilled the new one is punched for the locating screw.
