X axis Issue (videos inside)
- Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
got some issues with the x axis, every few months it snaps the belt.
please watch these videos closely
here my holding the stepper by hand trying to keep it as straight as possible, you can clearly see the stepper jumping.
https://www.youtube.com/watch?v=zIy6T6yE9jY
so now to try narrow down if its the stepper of x axis
you can clearly see the drill here jumping
https://www.youtube.com/watch?v=lp-cu9Hml1s
very wobbly drill
https://www.youtube.com/watch?v=nsxI3tgn-xE
anything got any thoughts?
very wobbly drill
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: X axis Issue (videos inside)
Have you got the correct belt, you may have a metric belt on an imperial pulley.
Starmills with ATC
The current belt I got off ebay
Is this the correct belt?
http://uk.rs-online.com/web/p/timing-belts/4749434/
4 Quatros
3 Oracs
2 Easiturn atc
Looks like the right one, how about the grub screws holding the pulley on could it be proud of the pulley surface.
- Hardware/Software: Denford VR Milling
Bobcad V28 Mill/Turn CadCam software
Fanuc
Haas
Heidenhain
Inspect3D
I'm having an issue with my x axis on my triac also. it machines circular parts with steps as if the datum point shifts. no matter what speeds i use it always shifts
I've bought a new stepper motor for it that was supposed to be the correct one. but it has 8 wires instead of 4. looks exactly the same as the one in your video.
4 Quatros
3 Oracs
2 Easiturn atc
check the x and y gibs and drive end bearings
Starmills with ATC
when you removed the original stepper from your triac how many wires were being used?toby1995 wrote:I'm having an issue with my x axis on my triac also. it machines circular parts with steps as if the datum point shifts. no matter what speeds i use it always shifts
Fanuc
Haas
Heidenhain
Inspect3D
i haven't removed the original motor but it has 4 wires, i bought a replacement just like in the video and it has 8 wires.
Starmills with ATC
I bet if you strip the wire leading to the original stepper there is actually 8 in theretoby1995 wrote:i haven't removed the original motor but it has 4 wires, i bought a replacement just like in the video and it has 8 wires.
Fanuc
Haas
Heidenhain
Inspect3D
turns out it was 8 wires but was just using 4 like you suggested.i accidentally shorted the extra wires and had to replace the fuse on the axis "0" drive board. I've just wired up my new motor and ill do some accuracy tests when done to see if it can machine circles accurately now.
the new motor takes a lot more torque to rotate it when no power is present. the old one was smooth and i think it may have been knackered as their should be some resistance to being rotated but there was almost none
Fanuc
Haas
Heidenhain
Inspect3D
all sorted! accurate little machine now. thanks for the advice
Starmills with ATC
the issue was the stepper?
Fanuc
Haas
Heidenhain
Inspect3D
its appears to be. it must have been worn somehow. i have no issues when machining now. is this problem with steppers uncommon?
