X Stepper Keeps Dying
Re: X Stepper Keeps Dying
Post by Martin » Thu 31 Oct , 2013 10:47 am
Strange, As long as you are sorted now.
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Thu 31 Oct , 2013 11:00 am
nope not sorted sadly.
a brand new stepper died, although this shouldnt have been caused by only wiring in 4 coils.
what is a likely cause of a brand new stepper dying? coould a faulty drive cause this?
ill have to get a new stepper and look to wire in all 8 coils, i just dont want it to die after a month like this one
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Post by angel-tech » Thu 31 Oct , 2013 11:21 am
what are the colours of all wires, and which ones do you have wired.
andy_con
Starmills with ATC
Post by andy_con » Thu 31 Oct , 2013 11:32 am
this is the stepper I got
http://astrosyn.com/section.php/55/1/my34hy_series_1_8
the 3.1amp one
don't know all the colours off hand but see below for what I wired in
Post by Martin » Thu 31 Oct , 2013 13:15 pm
What have you done with the blue, black, brown, green?
It does not look correct from what I can see.
Use The red & orange as one pair. The blue & green as the second pair & link the yellow/white & black/brown as pairs
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Thu 31 Oct , 2013 14:49 pm
Andy if you have a good multimeter you can identify the coils by their resistance
Post by Martin » Thu 31 Oct , 2013 15:37 pm
Yes, Thinking about we have had a couple of motors recently where the colours did not match with the relative windings.
andy_con
Starmills with ATC
Post by andy_con » Thu 31 Oct , 2013 15:51 pm
tom that's actually how we wired it in, we used a multi meter the check how the existing one was wired. then wired the new one exactly the same
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Thu 31 Oct , 2013 17:57 pm
what resistance do you get across one coil without it connected to the driver. Make sure the driver is off before you disconnect.
Post by Steve » Fri 01 Nov , 2013 10:06 am
The motor would not have been supplied with only 4 wires connected. I suspect the 4 wires shown would have been paired up to put the windings in series.
The motor would be 3A and depending on the stepper drive be wired in parallel (for 4.2A Drive) or series for the standard Denstep 2A drive.
Can you tell me the drive you are using and its supply current?
The part number of the motor you are using?
How has the motor failed? Can you take a reading of the phase resistances for each phase of the motor?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Tue 05 Nov , 2013 18:05 pm
have you got any further with this.
PS. I have some BT35 holders in if you need any.
andy_con
Starmills with ATC
Post by andy_con » Thu 07 Nov , 2013 19:56 pm
I haven't no, my daughter hasn't been well so I've not been in the workshop much.
I just purchased 7x bt35 tool holders for £10 each ;)
What you got?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Thu 07 Nov , 2013 21:54 pm
er32's and a few sidelocks.
andy_con
Starmills with ATC
Post by andy_con » Thu 07 Nov , 2013 22:13 pm
ok cheers, im only interested in da200's or da180's. but thanks for the offer
andy_con
Starmills with ATC
Post by andy_con » Thu 28 Nov , 2013 16:30 pm
grrr.... again today the stepper is missing steps again.
this is such an annoying fault that im struggling to get to the bottom of
swap x and y drive card round today just to check that again and its 100% not the drive card
andy_con
Starmills with ATC
Post by andy_con » Fri 29 Nov , 2013 14:37 pm
ok heres the problem.
not sure how well you can hear it on this video, but I tried.
listen to the knock knock knock coming from the tables, its the table missing steppes.
drive card checked and work fine - swapped x and y card round and the issue was still on the x
checked wiring between cabinet and actual mill and again fine
Ethernet cable comes into control cabinet and into a smooth stepper, smooth stepper goes into a big control board, which then feeds into tom's board, which converts 5v into 24v or whatever the digi cards need.
checked toms board and again fine.
really stuck what to do now
[video]https://www.youtube.com/watch?v=o3rFml6VkYg[/video]
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 29 Nov , 2013 16:34 pm
i can't get the link to work.
andy_con
Starmills with ATC
Post by andy_con » Fri 29 Nov , 2013 16:39 pm
listen at about 10 second you can just about hear it
ive done so many things today but I cannot solve the issue or get it to appear on the Y
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 29 Nov , 2013 16:43 pm
it's set to private
andy_con
Starmills with ATC
Post by andy_con » Fri 29 Nov , 2013 16:50 pm
try now
