Help Broken Belt on Triac
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Sun 05 May , 2013 21:29 pm
Machine was doing its thing and the X stopped working.
took the stepper out and i have a broken belt, help!
how/where do i get a replacement from and how do i replace it?
andy_con
Starmills with ATC
Re: Help Broken Belt on Triac
Post by andy_con » Sat 11 May , 2013 10:26 am
belt replaced
where is the Y servo? would it be located under the Z column?
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Post by angel-tech » Sat 11 May , 2013 17:35 pm
yes it is, access is from the back.
andy_con
Starmills with ATC
Post by andy_con » Sun 12 May , 2013 10:30 am
ah ok, is there a panel or something?
due to the limited space in my workshop i cant access the back of the machine to check, so just thought id make enquiries encase i get any issues
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Sun 12 May , 2013 10:52 am
it's at the base of the pillar.
andy_con
Starmills with ATC
Post by andy_con » Sun 12 May , 2013 11:52 am
cool thanks, hopefully i wont need to move the machine but you never know
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Sun 12 May , 2013 12:52 pm
if you intend to replace the y belt you'll need a fair bit of room as it's a little bit tight to get at it.
andy_con
Starmills with ATC
Post by andy_con » Sun 12 May , 2013 18:37 pm
no i only plan to replace it if it breaks, otherwise im leaving it alone.
should i even ask where the z belt is?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Sun 12 May , 2013 18:39 pm
inside the pillar, if you take off the pillar top plate you'll see it.
andy_con
Starmills with ATC
Post by andy_con » Sun 12 May , 2013 18:51 pm
ok cool thanks
