Hello,
       A question about the depth of cut in quickcam 3d. I made an stl file in prodesktop the max depth of the contour is 1.5 mm I set the depth of cut in quick cam to be 1mm but when the nc file was generated it cut the 1.5mm depth in one pass? I wondered what i might be getting wrong?
                  Thanks for any help.
    				    			In the latest version of QuickCAM 3d (v3) and QuickCAM Pro, the total depth of cut is determined within each machining plan in the Machining Boundary setting for Z
Machining boundaries allow you can create toolpaths confined within a 3D region of the model.
The Step down amount on some plans is there to cut down the material in set depths so as not to cut deeper than the flute length will allow.
The Cut Depth wizard page is where you set the absolute maximum depth of any cuts (effectively ignoring any parts of the model below this point)
Make sure you have the latest versions as they are much improved from the early versions
Ahh yes  I'd forgotton about that in the old version (it is a few years now since I used it)
It used to run the first full pass at a lower feedrate didn't it ?
I suspect its now gone because the code is basically a restricted version of QuickCAM Pro which has extra different styles of toolpath, where this feature just wouldn't work.
