Spindle control
Posted: Fri 19 Jan , 2024 22:49 pm
by b1pea
Hi, looking for information regarding Fanuc o-t control. I had to change the memory card and lost the parameters. I have the parameters back in but do not have access to the 6000 parameters, which I believe are the spindle controls. I can input spindle commands in the control and the control reacts as expected, but the spindle doesn't start. No alarms are showing. Yang ML 25A. Spindle was working before the memory card was changed.
Re: Spindle control
Posted: Tue 23 Jan , 2024 8:59 am
Have you installed the 450 Diagnostis?
Re: Spindle control
Posted: Sun 28 Jan , 2024 21:45 pm
by b1pea
Thanks for the reply.
I changed the Diagnostic on the control , D0450, to the setting it was at prior to doing any work on the machine. I still do not have any 6000 diagnostics showing up. Am I right in assuming that I should have these diagnostics?
We have another machine of the same type although slightly smaller with the same control which does show diagnostics in the 6000's .
Re: Spindle control
Posted: Mon 29 Jan , 2024 10:01 am
What machine do you have?
I am not aware of the 6000 Diagnostics.
Have you set Diagnostic 453 bit 0 to 1?
