Nova Turn machine
Robert
Nova Turn machine
Post by Robert » Tue 03 Feb , 2015 17:58 pm
I bought a Nova Turn machine.
Serial nr: FO4861/3
Date of production: October 1996
Software Windows 3.11,
I am working a LateCam Design 1.3. of course I have got a orginal license key.
I want to work on this program on new Window XP or 7.
I downloaded a LateCam - version for new Windows but the license key doesnt work.
Thats why I want to registration on Your Forum.
Thank You for Your help.
Robert
TDIPower
Re: Nova Turn machine
Post by TDIPower » Tue 03 Feb , 2015 22:32 pm
I have LatheCAM designer V1.11 and it works no problem on XP. I tried it in Windows 7 but it won't install. Having said that I did not try installing under compatibility modes (ie telling win 7 to install/run in XP mode).
I believe it won't run under Win 7 or later as the design of the software is not supported by the later processors. You may need to get an older PC. You just need something from around the same time.
If you want to use the newer version you need to buy a new licence. I am in the same situation.
It is worth checking what software you currently have to control the novaturn and what version the novaturn can work with. If you are wanting to use a later design program because you want to run it on a later processor or WIN 7 machine you may find the control program for the novaturn wont work on it as well. So you may need to upgrade the control program for the later processor/operating system if the Nova Turn will support it.
Post by Martin » Tue 03 Feb , 2015 23:53 pm
this is the link to the Denford Vista, Windows 7 and Windows 8 Compatibility chart.
http://website.denford.ltd.uk/support/8 ... a-win7-art
gilles310
Post by gilles310 » Wed 04 Feb , 2015 8:59 am
lathecam works perfect with xp sp3
