Can I use older software to get this Microturn Lathe running
ChandlerW
Hardware/Software: Denford Microturn
Post by ChandlerW » Mon 24 Dec , 2012 0:11 am
Can I grab some legacy software from here https://website.denford.ltd.uk/support/9 ... s-software
Use the Flashes.txt to unlock the software and use that to run my Microturn lathe?
I can dig up a WIN98 disk and setup an older computer to run the software.
IF all the above is correct do I need a certain cable to hook up from my com port to the 25 pin port on the lathe?
I have another thread where I ask about using Mach3 and a driver board but if I can get it up and running using the original software I'll go that route.
Of course I'm not sure of my options, I just bought the lathe.
Re: Can I use older software to get this Microturn Lathe run
Post by Martin » Mon 24 Dec , 2012 0:36 am
What is the color of the seven segment LED? If it's red what version is the Eprom?
ChandlerW
Post by ChandlerW » Mon 24 Dec , 2012 4:00 am
2.0B/10/S/B/B19/JD5
The seven segement display is red.
Post by Martin » Mon 24 Dec , 2012 8:09 am
I think that is a VR Eprom so none of the legacy Dos software would connect.
We do sell single user licences of the VRTurning software.
Where are you located?
ChandlerW
Post by ChandlerW » Mon 24 Dec , 2012 12:07 pm
Texas , US
Post by Martin » Mon 24 Dec , 2012 13:01 pm
You would need to contact your local agent for a price.
