Hi all,
The school that we support has just purchased LaserCAM 2D Design and want it installed on several machines.
Rather than manually install onto all the machines I was wondering if there was a way to install it on the network?
I had a bit of a test but got loads of .dll and class errors.
Many thanks in advance for your help!
Kevin.
Install LaserCAM 2D Design over a network
Re: Install LaserCAM 2D Design over a network
Can't you distribute the MSI package ? eg: http://www.windowsnetworking.com/articl ... tions.html
This will then copy and register the .ocx files required by LaserCAM, eg: programfiles\Denford\Common\VeCad.ocx
Otherwise, you can probably get it to work by copying all the files to the correct location (you can tell from the directory on the CD) and then registering the few files that complain, like VeCad.ocx.
