NAN in the axis-lines after try homing
Hi folks!
I have a probleme with my Microturn 2000NS / VR Turning v1.22
I was just running a very simple file and it worked out fine. Then i shut down the PC to see if it still works after restarting everything. Well it didn´t :(
The folloing Problem occured:
When I tried to Home the machine, it made a real bad sound and vibrations. The machine controll window showed "NAN" in both Axis-lines and Feed was set to 0%
When I checked the work piece offsets in the current offset for X and Z Offset the Distance to origin field showed "NAN" as well.
Restarting everything again and choosing different offsets couldn´t fix the problem. I´ve also checked the manual feedrate knop - it´s stillin it´s position. The VR Machine still works fine.
Thanks for any help.
Re: NAN in the axis-lines after try homing
I think this will be the problem: viewtopic.php?f=2&t=54&hilit=nan
(Regional settings using comma , for fractions instead of a decimal point .)
Mr Magoo, Martin, Steve
