NOVATURN TNR comp
Rich
NOVATURN TNR comp
Post by Rich » Fri 31 Oct , 2008 18:52 pm
Hello,
We are running a 1999 NOVATURN with vr turning version 1
when using g41/g42 the simulation just stops ? also the machine has a front toolpost but when I change the tool configuration the simulation wont use the tools I have ticked front toolpost in the parameters
any ideas ?
Post by Denford Admin » Mon 03 Nov , 2008 10:00 am
Have you got the latest version v1.19 ?
http://www.website.denford.ltd.uk/suppo ... -downloads
Rich
tnr comp
Post by Rich » Mon 03 Nov , 2008 11:50 am
Hello,
got the new version but still having problems with this prog. on the finish cycle machine stops on the z-48 line.
O1201;
G21;
G50S3000;
G40G99;
T0101M06;
G96S200M3;
G0 X27 Z0;
G1X-1F0.2;
G0X27.Z2.;
G71U2.R1.;
G71 P100 Q101 U.25 W.25 F0.25;
N100 G0 X7. G41;
G1 X15.9 Z-2.5 F0.15;
Z-20.;
X18.;
X20 Z-21.;
Z-35 R1.;
X23.;
X25. Z-36.;
Z-48.;
N101 X28 G40;
G70 P100 Q101;
G28UO W0;
M30;
Rich
Post by Rich » Mon 03 Nov , 2008 13:42 pm
Found it
letter o instead of zero in g28 line :oops:
Post by Denford Admin » Mon 03 Nov , 2008 15:30 pm
G28UO W0;
There is a letter O in the program instead of 0 (zero)
Maybe the software should look for this kind of thing and tell you about it though :oops:
Post by Denford Admin » Mon 03 Nov , 2008 15:31 pm
sorry - posted that before seeing your reply - double :oops:
Rich
Post by Rich » Mon 03 Nov , 2008 19:52 pm
Thanks anyway,
Another question (sorry to be a pain) we have a denford tutor board with the machine .can this be used to operate the machine ?
Thanks.
Post by Denford Admin » Tue 04 Nov , 2008 9:44 am
Yes - you'll need a spare RS232 COM port on the PC.
Then go into Setup > Machine Parameters (denny) > Input/Output Devices and set the COM port number (default is 0) which the tutor is connected to (eg 2 for COM2:)
