v1.13 Fix to default Z height when Billet bounds selected...it should have set the cutplane height for min Z, not the bottom of the billet. (error was introduced in v1.12)
check here to download the latest version:
http://website.denford.ltd.uk/index.php ... -downloads
QuickCAM PRO v1.13 released 7th Nov 2012
Re: Quickcam Pro - creating machine code.
Hi, Sorry for what is probably a basic question, but could you kindly bullet point the stages required to transfer the code from a planned and saved bitmap image within quickcampro to vr milling program? I'm either expecting the imposible or missing the obviouse.
Many thanks, Graeme
Many thanks, Graeme
Re: QuickCAM PRO v1.13 released 7th Nov 2012
This post has the Lithophane tutorial which can also be got from the Help menu in QuickCAM Pro
viewtopic.php?f=6&t=639
There are some more .pdf help files here (for different software but the machining advice will be the same):
viewtopic.php?f=6&t=2596
