Relay for the Emergency stop button ?
- Hardware/Software: Denford microrouter 2000? Windows 98
Hello is this the relay for the Emergency stop button ? It likes to buzz when the e stop is off and I get the “ stop” code .
- 3C789DFD-8ADE-433E-A5FD-274AFD5C1105.jpeg (474.76 KiB) Viewed 6591 times
Re: Relay for the Emergency stop button ?
This is the nearest drawing I was able to locate.
You should be able to trace the wires back.
- 1995 MicroMill (MicroTurn) Wiring Diagram.pdf
- (1.16 MiB) Downloaded 267 times
Thanks Martin ( again ) ohm the relay wires back to the emergency stop button . It’s connected to the relay : both wires are showing it’s connected . This Relay likes to buzz all the time . I know that could mean low power or low voltage . I’m gonna put a new relay in and see what happens . At least if it’s good . I’ve eliminated one idea. Hopefully that’s it .
