Which EPROM version in a DenStep card?
Mr Magoo
Post by Mr Magoo » Thu 25 May , 2006 22:16 pm
Can anyone tell me what the latest version number should be of the EPROM fitted in a DenStep card?
I've been chatting with a guy who's got a machine that works with his original DOS software, but not with the most recent(ish) DOS stuff. I remember that in the early days there was a few EPROM versions in circulation, then after a year or so things settled down and the majority of machines were shipped with a version something like...
1.6s/JD5
or something!!
Can anyone confirm?
Enny
Post by Enny » Thu 25 May , 2006 23:54 pm
Hi!
My TRIAC VMC is fitted with ATC and labelled as:
Model: TRIAC VMC
SerialNo.: EO 4026
DespatchDate: Feb 1992
ExportNo.: 4026
The EPROM is labelled as:
“ MINT 3.28 V1.05c/S “
Enny
Post by bradders » Fri 26 May , 2006 8:31 am
James
According to Mr Harrison the latest and longest running version is
V1.6h/S-JD5
Post by Denford Admin » Fri 26 May , 2006 16:39 pm
Not sure whats what here :? - but have put two of the later Eprom HEX files here:
http://www.denfordata.com/downloads/dos/MINT1_61.HEX
http://www.denfordata.com/downloads/dos ... 5_SJD5.HEX
Now all you have to do is find a spare M27C512-70 EPROM to try it out
Good luck :wink:
Mr Magoo
Post by Mr Magoo » Wed 31 May , 2006 5:13 am
I'm struggling to remember which EPROM versions match which software package, but I think that...
v1.6h/s-JD5 is used in cotrollers linking to the windows VR Turning and Milling s/ware
V1.05c/S is used on controllers linking to the old DOS software.
So if you're trying to get your old DOS machine up and running again, don't bother trying to fit v1.6h/s-JD5
The thing I can't rememebr is the latest ver of the DOS chip. Enny has v1.05c/s but I'm not sure that was the latest release. I wonder if Mr Harrison knows if there was a later vbersion?
A note of caution for anyone looking at updating EPROMS. Some early control cards ran at a slower clock speed than the later ones. Check the value written on the silver clock crystal mounted in the middle(ish) of the control card. Most were fitted with a 16Mhz crystal and can have EPROMS changed. Older cards ran at either 8Mhz or 12Mhz and updated software is NOT available for these cards.
Post by Denford Admin » Wed 07 Jun , 2006 9:25 am
Mr Magoo had it right the first time:
EPROMS marked:
ESMINT3.28 V1.6H/S-JD5
are for machines controlled by DOS software only.
So, the previous HEX file is the latest of the DOS firmware.
Any EPROMs marked v2.0 v2.0 BETA and v2.1 are the newer firmware which will talk to the Windows control software. These EPROMS will only work on a control card with a 16Mhz crystal/clock.
These DOS to Windows upgrade EPROMS could still be available at a reasonable cost - you will need to contact Denfords
Hope this clarifies the EPROM situation :?
jmini
Clock speed
Post by jmini » Tue 20 Jun , 2006 19:07 pm
Hi all
Mr Magoo mentioned clock speeds of 8 12 & 16 mhz
I have had a look at my own board and it is fitted with a 14 Mhz crystal.
Have tried both new versions of eprom file but neither work so is it
posible to change this crystal or do other components need to be changed
as well ?
On the subject of the eprom hex files do the blank eproms need to be
formated with "FD"s instead of the normal FF to fill in blank spaces
as apears to be the case in my original eprom (v1.05) ask's my expert.
we tried both methods but because of the possible slow clock we were
unable to get any usefull results
Thanks to all who have helped me get this far
jmini
Post by Denford Admin » Wed 21 Jun , 2006 9:00 am
The 16Mhz clock is ONLY necessary if you wanted to update the control firmware to run windows VR Milling/Turning. We just use the crystal just to help us identify the boards' processor and revision.
The latest DOS control software should be matched with the latest EPROM version and the clock speed should be left as is - it matches whatever processor was fitted. You would have communication timing problems if the clock was changed.
So, if you have the latest DOS s/w and ESMINT3.28 V1.6H/S-JD5, then all should work :shock: - if not check your .GO file settings are as your original DOS disk.
jmini
Post by jmini » Wed 21 Jun , 2006 20:39 pm
To Denford Admin
The .opt & .go files were copied from my current version into the new
version directory so were identical
The new eproms when fitted both displayed "L" on the card display with a
flashing dot in the lower left corner instead of the "8" displayed on the
original eprom any ideas would be most welcome
On the subject of sending a file to denford admin do I send it as an
attachment to service@denford.co.uk
if so for the the attention of who?
Thank's jmini
Mr Magoo
Post by Mr Magoo » Wed 21 Jun , 2006 21:52 pm
I'm pretty sure the EPROM versions were created for a specific speed of processor, and the "JD-5" version was only every compiled for a 16MHz board (so Denfords will not have a "JD-5" eprom compiled to run on a 14MHz board - unless Mr Harrison knows different???)
(Technically: I believe the divisor value used to generate the serial RS232 clock speeds are in the EPROM firmware, so wrong EPROM and the serial baudrates are all screwed - and probably other timing related issues too! This is why you get the red LED "L" but can't talk to the board)
Regarding changing the crystal - I wouldn't recommend it, but if you still want to give it a go (it might just work :shock: ), first check the numbers printed on the main processor on the control card. The last few digits indicate it's max clock speed (I wouldn't recommend over-clocking!!!)....
.. KB12 = 12MHz
.. KB14 = 14MHz (also KC14 I think)
.. KC16 = 16MHz
:shock:
Post by Denford Admin » Thu 22 Jun , 2006 8:53 am
You can send any files for posting to Denford Forum Admin at technical@denford.co.uk
or just email the Denford Admin user (me) from here.
jmini
Post by jmini » Mon 03 Jul , 2006 19:46 pm
Hi all
tried changing the crystal to 16mhz after checking the processor speed (KC16)
unfortunatly still the same "L" display and error 50
So I am look for any more help or sugestions
thanks
jmini
MAX THE MILLER
Hardware/Software: Denford Triac PC. VR Milling 5.51.0.616
Re:
Post by MAX THE MILLER » Sun 16 Jul , 2023 21:54 pm
Good luck :wink:
Is a HEX file available for the V2.1 EPROMs used with Eurostep controllers?
Thanks, Max.
Re: Which EPROM version in a DenStep card?
Post by Steve » Tue 18 Jul , 2023 16:02 pm
Hi Max,
I dont think we have any Hex files now.
MAX THE MILLER
Post by MAX THE MILLER » Wed 19 Jul , 2023 7:57 am
Thanks Steve.
I don't suppose you have any version 2.2 EPROM's available?
Or perhaps a forum member has read the EPROM's contents using a programmer?
Post by Martin » Wed 19 Jul , 2023 9:55 am
We never did a 2.2 Eprom
I found the HEX file for a 2.0 Eprom which is very similar to a 2.1 Eprom.
MINT2_0.zip
(58.94 KiB) Downloaded 545 times
MAX THE MILLER
Post by MAX THE MILLER » Wed 19 Jul , 2023 10:16 am
Sorry. My error, I meant V2.1.
Thanks for the HEX file.
