DOS and VR EPROM Versions
Post by Steve » Fri 27 Nov , 2020 10:26 am
Here is a list of the EPROM numbers fitted to the Smartstep, Denstep and Nextstep controller cards.
All the machines were supplied with DOS software before 2000 and a change over to the current VR Turning and VR Milling software in late 2000.
To identify what software will run on your controller you can simply check the version of the EPROM fitted to the control card.
If you have a DOS EPROM then you cannot use the latest VR Software without replacing the EPROM
DOS AND VR EPROM VERSION NUMBERS.pdf
(7.12 KiB) Downloaded 494 times
Re: DOS and VR EPROM Versions
Post by Steve » Tue 16 Mar , 2021 9:29 am
EPROM LOCATION NEXT STEP CARD
Post by Steve » Wed 24 Mar , 2021 9:39 am
EPROM LOCATION SMART STEP CARD
SMARTSTEP EPROM.jpg (218.83 KiB) Viewed 10103 times
