TDS 1/1 Feeds and speeds plate
Just wondered if anyone could send me a good picture of the speeds and feeds plate that goes below the dial, mine is missing, I might be able to make one on my laser with a good picture.
A WMD25V mini mill.
Re: TDS 1/1 Feeds and speeds plate
I think what the plate says may depend on the model of lathe,i.e. Metric or Imperial.
Mine is metric.
Mine is metric.
Yes mine is also metric
Is this the 12345 dial on the gearbox?
If so I might have a spare
Hi, yes the dial on mine is 1,2,3,4,5, do you want to sell it to me?
Thanks.
Thanks.
Is this the thing you need?
- denfordplate.jpg (93.54 KiB) Viewed 9380 times
Yes thats the one i need
Ok send me a message with your address, pay the postage and it's yours.
I seriously recommend you make your best effort to change that front plate without removing the gear change lever though. It has an odd number of splines and teeth on the rack gear and if the pinion disengages it's easty to trash the gears by not getting it back in with full engagement.
- Hardware/Software: Denfird viceroy lathe
Long shot here but can you remove that front gearbox cover without removing the gear selector lever.
