Sharpedge TDS 12/16 & TDS 12/10 information
Hopefully all the Sharpedge info you'll ever need.
(with some TDS lathe info mixed in as well)
- Denford-Viceroy-Sharpedge-Leaflet.pdf
- (303.08 KiB) Downloaded 1468 times
- 16inch-Edge-Tool-Sharpener-Poster.JPG (208.25 KiB) Viewed 19601 times
Re: Viceroy TDS and sharpedge A3 arrangement drawings
Would it be possible to add the attachment please. Hopefully the information will be off use in answering my query from yesterday.
Re: Sharpedge information
I'm doing it now but something is struggling to cope somewhere.
Drill Sander sharpedge brochures and parts lists
- Drill-Sander-sharpedge-brochures-and-parts-lists.pdf
- (4.8 MiB) Downloaded 2932 times
Sharpedge Grinding Wheel Details
and
Sharpedge TDS 1216 General arrangement
and
- Sharpedge-TDS-1216-General-arrangement.pdf
- (152.78 KiB) Downloaded 1601 times
- Sharpedge-Grinding-Wheel-Details.pdf
- (26.3 KiB) Downloaded 1520 times
TDS 12 and 16 Sharpedge instruction manual
and
Viceroy TDS29 sharpedge Setting Instructions
and
- Viceroy-TDS29-sharpedge-Setting-Instructions.pdf
- (181.53 KiB) Downloaded 1510 times
- TDS-12-16-Sharpedge.pdf
- (487.74 KiB) Downloaded 2292 times
- Viceroy-TDS-and-sharpedge-A3-arrangement-drawings.pdf
- (785.17 KiB) Downloaded 1823 times
Re: Sharpedge TDS 12/16 & TDS 12/10 information
Sharpedge gearboxes apparently changed several times over the years, and it looks as though the top Oilite bush also changed. These drawings will hopefully help to identify the variations.
The Oilite bushes appear to be standard sizes - such as can be found by this supplier (Usual disclaimer applies)
Edited to replace (hard to read) drawings with Black & White versions
- SH_GEARBOX.pdf
- Gearbox versions
- (41.43 KiB) Downloaded 900 times
- SH5008_OILITE.pdf
- Bushes
- (25.11 KiB) Downloaded 952 times
