280VS and Synchro drawings and data
Parts lists for vari-speed lathes - 280VS and Synchro
http://www.denfordata.com/downloads/for ... 8-1979.pdf (36Mb)
280VS Headstock Arrangement.pdf
- 280VS Headstock Arrangement.pdf
- (113.87 KiB) Downloaded 1573 times
- Bogus105
- Hardware/Software: Viceroy T.D.S 1/1 GBL and TSA-16 lathes, Klopp 300 metal shaper, RF_45-like chineese benchtop mill machine
Re: 280VS Headstock Arrangement on pdf
Have you got similar scan of headstock arrangement but for TDS 1/1 GBL lathe? I'm looking for any explaination on how headstock and bed are aligned? What is the purpouse of headstock strip ( ML100/405 item)?
Not sure if this has already been posted but it may contain something similar:
viewtopic.php?f=50&t=3921
Wiring diagrams for 280VS and Synchro lathes:
SK 601, SK601A & SK601B - 280VS lathes with pendant control box, 3ph & 1ph
SK633 & SK634 - Synchro & TDS1 lathes, 3ph & 1ph
SK641 - Synchro control box
- 280VS and Synchro Wiring.zip
- 280 lathes wiring
- (538.02 KiB) Downloaded 1287 times
Re: 280VS and Synchro drawings
Tailstock Arrangement and detail drawings (and some mod notes)
Drawing Numbers:
BVS 100/750
BVS 100/751
MVS 100/709(A)
MVS 100/709(B)
MVS 100/706(A)
BVS 100/706
MVS 100/706(B)
MVS 100/705M
MVS 100/705
MVS 100/708(B)
MVS 100/708(A)
BVS 100/752
MVS 100/707
MVS 100/708
MVS 100/704(A)
MVS 100/704(B)
MVS 100/705E
Drawing Numbers:
BVS 100/750
BVS 100/751
MVS 100/709(A)
MVS 100/709(B)
MVS 100/706(A)
BVS 100/706
MVS 100/706(B)
MVS 100/705M
MVS 100/705
MVS 100/708(B)
MVS 100/708(A)
BVS 100/752
MVS 100/707
MVS 100/708
MVS 100/704(A)
MVS 100/704(B)
MVS 100/705E
- Tailstock Mod notes 1977-80.pdf
- Modification notes on the tailstock
- (794.58 KiB) Downloaded 815 times
- 280 Tailstock Drawings.zip
- Detail Drawings
- (3.67 MiB) Downloaded 813 times
- BVS100-700 Tailstock Arr.pdf
- Tailstock Arrangement
- (713.98 KiB) Downloaded 776 times
Synchro Wiring drawings
Wiring diagrams:
A3-500018A
A3-500018
A3-500016
A3-500015
A3-500014 and
A3-500024
A3-500024A
A3-500018A
A3-500018
A3-500016
A3-500015
A3-500014 and
A3-500024
A3-500024A
BVS 110-400 Bed Arrangement
BVS 100-402 Bed
Please don't add comments to this thread.-
280VS Manual
Manual for the 280VS:
- Hardware/Software: User of Viceroy 280 VS Metal Turning Lathe with Down-Drive, variable speed by manual handwheel, electric control in bench. Viceroy 280 MVS
Re: 280VS and Synchro drawings and data
Hi everybody,
my name is Hans Jürgen and I am from Germany.
Since 40 years I own a Denford Viceroy 280 lathe in metric version and long bed ( 1 meter between centers ),
which I bought brand-new from a local dealer.
It is the version MVS , manual variable speed with hand wheel control.
It is most completely equipped with all available attachments and extras from that time.
Unfortunately, the documents and arrangement drawings that came with the lathe are for the last version 280VS with motor driven variable speed.
The lathe is still in very good condition, but I would like to replace the crossfeed and compound spindle and nuts, these are the most worn parts.
Trapez thread 1/2" x 2.5 mm, special thread to Denford specification.
Can anybody help with original manufacturing drawings for spindles and nuts ? I had them downloaded previously from this forum,
but somehow I lost them and cannot find them again.
Also, I would like to have the original arrangement drawings for the Headstock and Drive Arrangement for my lathe version.
Of course, all available drawings would be welcome.
You can contact me via Email: juergencyranski@aol.com.
Many thanks for your support.
Best Regards
Hans Jürgen Cyranski
Best Regards
