VLS honeycomb bed crashes into air assist cone
Posted: Thu 11 Dec , 2008 16:40 pm
by bradders
Posted: Thu 11 Dec , 2008 16:43 pm
by bradders
Note ?
IF a new computer is connected to a VLS laser and auto Z is not set, then the software will not know where the bed is and not home and hence could cause the bed to crash into the air assist cone
Posted: Thu 11 Dec , 2008 23:20 pm
The auto z only raises the bed or drops the bed to where it thinks the focus point should be.
It is best to home the Z axis each time you power up the laser cutter. The VLS 2.3/3.5 model needs to be told to home manually. It may be worth installing the fume extraction alarms in which is a option to "Home Z on Power Up".
Posted: Fri 12 Dec , 2008 7:41 am
by bradders
The VLS range and not the VL range as specified in the title
Posted: Tue 16 Dec , 2008 23:08 pm
by Andrey Anfimov
Before using Versalaser make calibrations for all kind of options.
Without calibrations Versalaser does not know where is "0" point and rise table very high.
Versalaser store calibrating value in memory on the CPU board. So it does not matter what computer you use with Versalaser.
Posted: Wed 17 Dec , 2008 9:15 am
by bradders
The VLS range of Laser's unlike the VL range stores the height settings on the PC and not the Laser CPU
Posted: Wed 17 Dec , 2008 11:21 am
by Andrey Anfimov
Where? What file stores the height settings?
Posted: Thu 18 Dec , 2008 20:08 pm
by Steve
The z datum position is stored on the lasers CPU.
You cannot access it. Just recalibrate.
First calibrate the lens to the engraving table then calibrate the cutting table.
