Triton - back lash
All info relating to the Denford Triton and Triton Pro milling machines. (Project Lead the Way)
Moderators: Steve, Mr Magoo, Martin, bradders
Benny
Triton - back lash
Post by Benny » Mon 04 Feb , 2008 18:32 pm
My Triton has a "back lash" movement and I would like to know to know how to eliminate --- is the linear slide going bad?
Benny
Triton - back lash
Post by Benny » Mon 04 Feb , 2008 18:39 pm
The linear slides have carriages fitted which connect to the slides. The slides have a ballscrew that drives it. The ball screws are anti backlash by design. If the nut has backlash then the whole ballscrew needs to be replaced. The more common cause of backlash is the bearing securing the end of the ballscrew or play in the pulleys or belt.
If the bearings from one of the carriages have come out --- the carriage alone (if no damage to the rail) or the linear slide could be replaced.
