Hi all,
I am somewhat new here with my triac and everything seems to be going well except occasionally the spindle makes some weird noises. I uploaded a video to YouTube the first half is the noise which happens occasionally (maybe for 5 mins every hour) and the second half is how it sounds the rest of the time... Nice and quiet. Anybody have any ideas?
https://youtu.be/xWIP7te0KVc
Thanks!
Alex
Occasional Weird spindle noise [video]
- Hardware/Software: MicroMill
FANUCSMD
Re: Occasional Weird spindle noise [video]
Hi, not sure but to me that sounds like a shaft spinning in a bearing. so the bearing is slowing down then spinning up. Would be worth taking the top cover off and having a look.
FANUCSMD
So that was my initial thought also. I have taken off the cover and it is a pretty simple setup. From what I can see there are only bearings for the spindle, which feel tight with my hands, but that doesn't mean that still couldn't be going bad?
hey not sure if its the same as mine but worth a look. if you take off the cover on the spindle housing on top of the motor were the tach-o is there was a little plastic cover over the shaft , presumably to keep dust out. mine keeps falling in and making a similar noise. sounds like a bearing gone bad. Had a moment my self thinking it had but it was just the plastic spinning in the hole. Might be the same hope it is.... good luck..
FANUCSMD
Thanks i will give it a look!
