Decel at end of each line of code
Posted: Sat 01 Jul , 2017 16:43 pm
by alextaylor23
Hi all,
I am just running my first program on my new triac using VR milling 2. My problem is the machine decelerates after each line of code and comes to a stop... Then accels to the next line resulting in a jerky motion. Is there a setting I am missing in VR milling 2 to set this to constant velocity?
Any help is appreciated!
Re: Decel at end of each line of code
Posted: Sat 01 Jul , 2017 19:57 pm
by alextaylor23
So doing a little more reading it sounds like data starvation. I am going to check the baud rate settings... Does anybody have the recommended settings for VR milling 2? Baud rate, stop bits, polling delay? Any other suggestions? I will also try a new cable though I wouldn't think it would be the problem?
Posted: Sat 01 Jul , 2017 22:36 pm
by alextaylor23
OK I figured it out. For those who may find this later there is a "turbo" mode that needs to be enabled in the auto run. Why it is not enabled from the beginning I don't know.
Posted: Mon 03 Jul , 2017 8:10 am
The Turbo button does now default to being on. Not sure which version of VRMilling it was changed but you can download the latest version from the Denford website.
Posted: Mon 03 Jul , 2017 16:26 pm
by alextaylor23
Thanks that is a good idea. Just looked at the version I am running and it is 2.14... So a little out of date. I will give it a shot!
