Triac feed rate setting in VR milling 2
Posted: Thu 25 May , 2017 0:36 am
Hi all,
I just acquired a triac with VR milling 2. When I go to jog the machine it maxes out at 39 in/min. The manual says 2500mm/min or roughly 100in/min. I went in and modified the machine feed rate parameters to match the values in the manual. Is this OK? Why was it not like this originally? Seems to be working fine with the adjusted parameters.
