wire 21 on SRR??
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
wire 21 on SRR??
Post by andy_con » Tue 13 Dec , 2016 15:24 pm
my triac keeps tripping the RCD when I turn it on
traced it back to wire 21 coming out of SRR relay, anyone know what this wire is attached to?
moray
Hardware/Software: Triac VMC
Re: wire 21 on SRR??
Post by moray » Tue 13 Dec , 2016 17:20 pm
According to the list of wire numbers I've made up, 21 is one of the spindle motor power wires. 20 being the other power wire.
Post by Martin » Tue 13 Dec , 2016 17:36 pm
Yes it will go to the spindle motor.
Have you checked the motor brushes?
viewtopic.php?f=47&t=3888
DavidB
Post by DavidB » Tue 13 Dec , 2016 17:52 pm
Also consider having an electrician check the functionality of the RCD. I had mine go bad but thought it was my inverter welder which tripped the RCD when turned on. The welder supplier checked it out and it all tested fine so I called in the electrician who diagnosed the RCD was faulty and replaced it and all good since. The electrician did say it was a good idea to test the RCDs with their test button every 3 months or so.
