Spindle Tab nut tightness?
- Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
when doing up the tab nut on the spindle how tight does it need to be? tight enough till it stops spinning freely? or tighter so there is no play (up and down play) in the spindle?
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: Spindle Tab nut tightness?
you have to set the right amount of preload onto the bearings so a fair bit of tightening is required
Starmills with ATC
Ok thanks.
So ignore the free spinning of the spindle.
Currently I've not done it mega tight and it does spin very freely, but it has a fair amount of up and down movement/wobble.
I'll keep tightening tonight
4 Quatros
3 Oracs
2 Easiturn atc
I don't know the correct torque to clamp it up to, you just get a good feel for it after a while. Needless to say there can't be any play in the spindle, and vice versa it can't be too tight. The most important thing is to get everything clean before you fit the bearings, and make sure they're fitted correctly.
Starmills with ATC
yep i made sure everything was spotless and they are fitted the correct way round.angel-tech wrote:I don't know the correct torque to clamp it up to, you just get a good feel for it after a while. Needless to say there can't be any play in the spindle, and vice versa it can't be too tight. The most important thing is to get everything clean before you fit the bearings, and make sure they're fitted correctly.
its just trying to get the tab nut sorted, like i say ive only done it up a little and the spindle moved up and down by hand. so ill tighten a bit more tonight and see how it goes.
thanks for the info
Starmills with ATC
after some faffing I think ive got it right.
id tighten the tab nut so there was no play then gently tap the spindle with a hammer and play would appear. so I kept tightening until I tapped the spindle with a hammer and no play appeared. now the spindle feels smooth and silent
4 Quatros
3 Oracs
2 Easiturn atc
maybe tighten up to the next tab, to put a small preload on the bearings.
PS i'm in now if you still want to ring.
Starmills with ATC
i did do that last night, the machine is pretty much back together now and ive ran the spindle and its sounds pretty good.
when i got the bearings i made sure they came with specs so i knew exactly what i was buying, i wanted to future proof them for a possible spindle upgrade. the bearings are rated at 19k rpm with grease lubrication or 26k rpm with oil lubrication. the bearing place were saying being open bearings as soon as they get warm/hot lubrication starts to run out.
well the bearings in a triac arent lubricated full stop.
anyone got any thoughts on this?
