Back Lash on X
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Back Lash on X
Post by andy_con » Fri 30 May , 2014 14:47 pm
got about 0.1mm of back lash on the x table, anyone got any tips to reduce it?
tightened the screw for each gib by about half a turn but didn't make any odds
Re: Back Lash on X
Post by Martin » Fri 30 May , 2014 15:20 pm
Tab Nut.
You will need to remove the X axis stepper motor & the Pulley on the end of the Lead screw. You will then see the Tab Nut & Tab Washer. You can push the Tab back then tighten the nut & lock it with the Tab.
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Fri 30 May , 2014 15:29 pm
um interesting maybe when I had to change the bearings in the x table I didn't do it up properly.
how tight should I do it?
thanks for the help
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Fri 30 May , 2014 16:31 pm
is this normal?
the table moves back and forth pretty easily (and no its not the vice that's moving)
[video]https://www.youtube.com/watch?v=tXiMJb4 ... e=youtu.be[/video]
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Fri 30 May , 2014 20:52 pm
sorted the issue above, but here is my 0.1mm backlash issue
https://www.youtube.com/watch?v=nf5j6zR ... e=youtu.be
any suggestions?
Re: Back Lash on X
Post by Martin » Fri 30 May , 2014 22:56 pm
TAB NUT!
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Fri 30 May , 2014 23:01 pm
lol
tightened the tab nut, but its made no difference
how tight? till it wont turn anymore?
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Wed 11 Jun , 2014 22:22 pm
well with a bit of help from tom I started taking the table completely to bits to try work out the problem
although the backlash issue is 100% not the ball screws, the ball screws are very very sticky. turns out the oiler isn't working which could well be the cause.
there doesn't seem to be any play/movement in the ball screws just very sticky (yes I have oiled), so its either leave the ball screws knowing that at some point in the near future they are going to need sorting or doing it now.
the sleeve that's needed to take the threaded bar out, anyone know what one I need and where to buy from? a link would be handy.
also this screw which is for the jib is fooked, I didn't do this it was already like it. anyone know where to get a new one?
andy_con
Starmills with ATC
Re: Back Lash on X
Post by andy_con » Thu 03 Jul , 2014 12:43 pm
anyone got any tips for tightening the tab nut?
when im tightening the table is moving making it hard to do up tight
