Oiling system on early Triac?
neil_f
Hardware/Software: Triac
Post by neil_f » Tue 01 Apr , 2014 11:55 am
Does the early all-green Triac have an oiler built in (can't see one in any pics of it)? If not, how is it oiled?
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: Oiling system on early Triac?
Post by angel-tech » Tue 01 Apr , 2014 14:50 pm
inside the pillar usually
neil_f
Post by neil_f » Tue 01 Apr , 2014 17:28 pm
angel-tech wrote:inside the pillar usually
Ah, OK, that would account for it. Thanks.
neil_f
Post by neil_f » Tue 01 Apr , 2014 18:04 pm
I take it that means you'd need to have access to the rear of the column in order to fill the oiler?
Which in turn would make mounting the unit on a bench well nigh impossible.
I presume that's why they moved the oiler outside the column on later models.
