X Stepper Keeps Dying
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: X Stepper Keeps Dying
Post by angel-tech » Fri 29 Nov , 2013 17:18 pm
it could be noise in mach or crap on the screw
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Fri 29 Nov , 2013 17:59 pm
Trouble us, is it's missing steps
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 29 Nov , 2013 18:04 pm
both would cause this, noise is where I would start.
Do you loose steps when the spindle is off ?
andy_con
Starmills with ATC
Post by andy_con » Fri 29 Nov , 2013 18:41 pm
Makes no odds spindle running or not
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 29 Nov , 2013 19:13 pm
there are settings for debounce in the smoothstepper config, have you set anything in there.
I'm not up on smoothsteppers so it's hard to advise, could you go back to the old setup and try it. It may be the smoothstepper that has the problem.
andy_con
Starmills with ATC
Post by andy_con » Thu 05 Dec , 2013 15:42 pm
tom in order to re tune the steppers I need some info, can you help?
I need number of steps per mm and lead screw pitch
do the drivers do half steps?
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Thu 05 Dec , 2013 18:54 pm
drivers are running half steps, 200 steps per, 1500 velocity, 150 acceleration, step pulse 5.
pitch is 5mm
andy_con
Starmills with ATC
Post by andy_con » Fri 06 Dec , 2013 0:36 am
tom you free for a phone call tomorrow?
ive pretty much rules everything out other than an issue with the table its self
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Fri 06 Dec , 2013 0:42 am
yes mate.
andy_con
Starmills with ATC
Post by andy_con » Sat 07 Dec , 2013 0:20 am
well what a busy day, I have finally found the cause of the long term issue ive been having with the x axis. two knackered bearings on the table which I replaced today.
the machine is now running very well.
tom is a star, had a number of phone calls with him today and he pretty much talked me though replacing them. top man many many thanks
when putting the bearing the opposite end to the stepper back I managed to damage it. I really struggled to get the lead screw back into the bearing.
so may need another phone call when I get a replacement bearing :)
