x belt keeps snapping
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Fri 19 Jul , 2013 19:17 pm
My x belt just snapped again, this is the second time in a few months.
The bed wasn't even under any pressure it was doing a tool change at the time. I notice when replacing there is no adjustment tor tension on the belt.
Any suggestions?
Re: x belt keeps snapping
Post by Martin » Sat 20 Jul , 2013 6:47 am
The only time I have seen the X axis drive belt snap on the Triac is when the axis has been driven to the end of its limit & then stalls while the motor is still turning/
In order to tension the belt you just need to push down lightly on the motor assembly as you fasten it on.
