triac spindle motor (servo)
Hi I have updated my triac with later steppers/drivers also mach 3.
The machine has the servo type spindle motor,
I would like to control it passively with just a switch and a pot for now,how do I do that?
is there any electronics schematics available?
cheers
tony
cheers
tony
Re: triac spindle motor (servo)
What drive does the Triac have?
not sure havnt pulled the tray out yet only got the machine yesterday ill post back later with the details.
for now serial number tr14039f built may 89
Tony
Tony
Will it be this ?
viewtopic.php?f=15&t=2275
No its a linx 80, is that good or bad?
Tony
Tony
Ok found the manual it all looks straight forward,hope it works,as i havnt put power to it yet.
if not Ive got a eurotherm 508 that should do the job.
is there any market for all the original triac electronics? as im mach3ing this with new steppers and drivers?
Tony
Tony
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
i may be interested in the drivers and psu, and the steppers.
Angel,
Im in worcester,whereabouts are you?
4 Quatros
3 Oracs
2 Easiturn atc
sunny Cardiff
Ok what bits exactly do you want?
4 Quatros
3 Oracs
2 Easiturn atc
stepper drivers, steppers, stepper power supply. Which stepper drivers are they, sd2/3 i expect.
ive got 3 drives and the xand y steppers no z stepper
steppers are mae? I assume it all works when you power up the base the screen comes on with no error messages?
Tony
Tony
4 Quatros
3 Oracs
2 Easiturn atc
i'm off to manchester sunday, would it be possible to pop in on the way home.
sure,but to be honest id rather you take the lot with you,ie the tray with everything minus the motor controller,which works!!
make me an offer i cant refuse! as it will save me ebaying it all can you pm me?
tony
tony
4 Quatros
3 Oracs
2 Easiturn atc
i'm happy to take the whole lot minus the inverter..
I'll pm you my number so we can have a chat.
