Triac VMC - Mach3 and Spindle feedback help
andy_con
Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
Post by andy_con » Thu 25 Oct , 2012 22:57 pm
anyone much about spindle feedback from a triac vmc to mach3?
andy_con
Starmills with ATC
Re: Triac VMC - Mach3 and Spindle feedback help
Post by andy_con » Sun 28 Oct , 2012 10:14 am
know one offer any advice?
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Post by angel-tech » Sun 28 Oct , 2012 10:54 am
the green triacs and some early white triacs had a sensor on the spindle you could use for a tacho, but the newer white triacs don't have it anymore.
andy_con
Starmills with ATC
Post by andy_con » Mon 29 Oct , 2012 0:08 am
mines green and white...
white outer casing and green bed inside
think mine from around 96
vid here showing colours
http://www.youtube.com/watch?v=rqX9G1pMw0c
is there a way to find out 100%???
thanks
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Mon 29 Oct , 2012 0:14 am
that looks like a newer one without the sensor, but as it's a 6 station toolchanger it may still have it. Remove the head cover and if it's there you should see it at the top of the casting.
andy_con
Starmills with ATC
Post by andy_con » Mon 29 Oct , 2012 0:25 am
ive nto got a clue what it looks like so dont know what im looking for, sorry
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Mon 29 Oct , 2012 0:28 am
It doesn't have one, but it would be easy to add a sensor. The hard bit is adding it into the wiring that goes through the hardinge connector.
PS. Did you get this machine from Daniel.
andy_con
Starmills with ATC
Post by andy_con » Mon 29 Oct , 2012 8:57 am
i sure did, you must be the chap he got it from, from wales. nice to meet/talk to you
can you link me up to a sensor, so i know cost and what this thing looks like?
i would recon it would be impossible to get a wire down that trunking. but i could cable tie it back to the main cabinet.
im assuming the sensor needs to be feed back to the spindle control board? if so where do i connect it to? and how do i get mach3 to pick it up?
sorry for all the questions
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Mon 29 Oct , 2012 9:27 am
I've sent you a pm.
