Question?
my triac is in my garage, in the winter when the temp drops to -** im concerned the coolant may freeze.
what do people recommend to prevent this? i was considering adding antifreeze but unsure if these corrode steel?
Coolant Freezing in Winter - Question
Re: Coolant Freezing in Winter - Question
The advice here is "Antifreeze: Don’t even think about it!"
Winter tip #3
Winter tip #3
- Hardware/Software: Triac Vmc with 6 station ATC
Starmills with ATC
rubbish thats going to causing em a few issues, stopping the coolant freezing
I suppose it depends how cold it gets ?
The additives in the coolant will more than likely reduce the freezing point so unless it's really cold it may not be a problem
Starmills with ATC
suppose it depends how cold essex gets this year lol
