Triac vs Novamill, which would you purchase ?
I have been searching for a Novamill for some time now. One has become available but I have also found an older Triac. I like the smaller size of the Novamill but the Z axis is very limited. I would like to know what are the real trade-offs of a Triac vs Novamill. I will be starting a retrofit to AC servo motors for a ( Novaturn / Triac or Novamill ). Any input would be appreciated.
Thanks,
Iron-Man
Re: Triac vs Novamill, which would you purchase ?
Triac.
Spindle motor power.
Travel.
Iron-Man wrote:I have been searching for a Novamill for some time now. One has become available but I have also found an older Triac. I like the smaller size of the Novamill but the Z axis is very limited. I would like to know what are the real trade-offs of a Triac vs Novamill. I will be starting a retrofit to AC servo motors for a ( Novaturn / Triac or Novamill ). Any input would be appreciated.
Thanks,
Iron-Man
Definitely a Triac :mrgreen: :mrgreen: :mrgreen:
I have a friend who is currently well through the retro-fit of Misubishi 400 Watt AC Servos and 1.3Kw AC Servo for the Spindle, very nice job and it will of course be able to rigid tap with the setup he is using. Control software will be Mach3.
Motion Control card is a Galil 4 axis so all the servos are on a closed loop system at the Galil Motion card
The original casting is the slightly older Green one but it is in excellent condition, I should know, he bought it from me :mrgreen: :mrgreen: :mrgreen:
I`ll try and get some photos for you if you want or I will ask him if he wants to put them up himself to show off his project ! !
Rob
Thanks,
Iron-Man
Rob
Rob
I purchased the Triac.
I would definitely like to see pictures. I will be using LinuxCNC (EMC2). Allen Bradley servos and amps for the Triac and Yaskawa servos/amps for my Novaturn retrofit.
Iron-Man
