orac build
radial junkie
Hardware/Software: in the process of a masive orac refit including case etc running on emc2
orac build
Post by radial junkie » Sat 16 Jun , 2012 22:33 pm
Hi everyone iam new to this site and cnc for that matter. I aquired a denford orac off flea bay it was a in a bit of a sorry state but after nearly 8 months work iam slowly getting it to where i want the orac to be it should be ready for test runs with linuxcnc in the next 2 weeks
now a super orac
work in progress
making a start
she will scrub up ok.jpg (72.04 KiB) Viewed 10547 times
Re: orac build
Post by Denford Admin » Mon 18 Jun , 2012 9:25 am
Looking good !
I take it you have access to some sheet metal work facility ?
radial junkie
Re: orac build
Post by radial junkie » Mon 18 Jun , 2012 9:57 am
yes and no the tray was built using the original tray and the consul bottom the case and door was produced from molds i made in GRP the skirt that goes round the tray was hand formed using to lengths of angle in the vise to hold the sheet and a rubber mallet to bend to shape same with the controller box onlly part that was cut was a 120 count spindle encoder wheeel which a friend laser cut for me everything else is hand formed.
radial junkie
Re: orac build
Post by radial junkie » Fri 22 Jun , 2012 19:51 pm
not done alot since last posting other than run the axis though linuxcnc iam hoping to make more progress this week , already acquired my next build its denford easimill the intention for that is a 5 axis setup using the 3 axis of the easimill with the other two axis coming from a rotary table .
Re: orac build
Post by Denford Admin » Mon 25 Jun , 2012 9:28 am
Just wondering how you'd go about programming 5 axes ?
I'd have thought the CAM for full 5 axis would be expensive...or is it more a case of: rotate job into position then do normal 2.5D programming ?
radial junkie
Re: orac build
Post by radial junkie » Mon 25 Jun , 2012 11:05 am
yes cams arnt the cheapest of software but i have access to camworks used by a freinds company, i belive camworks supports upto 6 axis
radial junkie
Re: orac build
Post by radial junkie » Sat 29 Sep , 2012 0:13 am
Just a short line to let everyone know the orac is up and running, just a few software configs to add to linuxcnc 90% of it is already done, aquired a denford easimill single phase just waiting on 2 harmonic drives 100:1 ratio for the 4th and 5th axis conversion, will post some pics of the orac might upload a vid the biggest problem was the 2500ppr encoders i added to the Z and X axis but 99% of the problem was linuxcnc being new to me but finding my way round it. just waiting on new chucks and tooling for the orac now going to 125mm chucks so first job is to machine new backing plates, I must say for a training lathe the accuracy of the orac is impressive
once the everything is adjusted using a dial gauge i achieved 0.01 mm variation on the z axis full length of the lathe test bar.
Re: orac build
Post by Denford Admin » Mon 01 Oct , 2012 16:38 pm
Yes please post some finished photos! The accuracy sounds great
triac
Re: orac build
Post by triac » Sun 13 Jan , 2013 12:31 pm
Hi Radial junkie
Could you please post some details of parts used for your Orac conversion, suppliers links would be very helpful.
Thanks, Emgee
