Triac NEE software?
PDodds
Hardware/Software: Triac '87 converted to mach3
Orac '85 converted to mach3
Triac NEE software?
Post by PDodds » Fri 15 Jun , 2012 15:13 pm
My triac has the NEE control system.
I would like to be able to drip feed Gcode to it from a PC using the rs232 interface.
Is there any software available from Denford to do this?
Paul
Re: Triac NEE software?
Post by Martin » Fri 15 Jun , 2012 17:52 pm
Hi Paul,
You can use Industrial Text Editor.
If you go to http://denfordata.com/bb/viewtopic.php?t=256 you can download it free of charge.
PDodds
Post by PDodds » Sun 17 Jun , 2012 13:06 pm
Thankyou Martin.
Is it possible to paste gcode into the editor, if I use another program to generate it?
Paul
Post by Martin » Sun 17 Jun , 2012 13:54 pm
Yes, It opens as a editor window so you can open text or paste it in.
PDodds
Post by PDodds » Fri 29 Jun , 2012 9:44 am
Thanks.
I am looking to buy some software which would allow me to create a model of what I am hoping to machine, and generate a gcode program that I could then use by saving to a disk, opening in the text editor, and run on the machine.
Is this possible, and which software would be applicable?
The serial number of the triac is TR030361, made in 1986, and control serial number 156.
If you could point me in the right direction, it would be very much appreciated.
Many thanks
Paul
Post by Denford Admin » Fri 29 Jun , 2012 10:29 am
There are a few CAD/CAM names to google and get you started:
viewtopic.php?f=60&t=3601
Lone_Ranger
Post by Lone_Ranger » Sat 30 Jun , 2012 9:33 am
PDodds wrote:Thanks.
Many thanks
Paul
Paul
Probably the best buy would be BobCAD-CAM, it is pretty easy to learn as it is what could be termed "Wizard driven", it has a full simulation of the part and the machine cutting, produces the G code and can be purchased with a G code Editor/backplot facility.
Here is a link to a small Demo I did of the softwares simulation running a small program, there is no sound on it but it will give you an idea of what the sim looks like.
http://www.alroracing.com/BobCAD%20Vide ... 82D%29.wmv
When you click the link it should automatically launch your Windows Media Player.
I will be doing some more videos with sound in soon so if there is enough interest here I will post links to them :) :D
Rob
