Accidentally our Triac Fanuc Controlled om machining centre was turned off whilst in edit mode. The 09001 program macro was lost and when trying to run programs now an 078 alarm appears. Can anyone help with the reprogramming of the 09001 macro as we do not have a copy.
Do you have the machine serial number and original customer name/location ?
There may be a possibilty the macro program is inside an old customer folder.
We've had a look at the Triac data we kept on floppy disks but unfortunately none of them are readable now
Thanks for your reply. The machine is still at the original address and ther were two 9000 macros which were deleted. I think the installing engineer was named John Brown but I understand he is no longer working for the company.
MERTHYR TYDFIL COLLEGE
SOUTH WALES
CF481AR
SERIAL NUMBER 30201B
JUNE 1
Steve France
SOUTH WALES
CF481AR
JUNE 1
Steve France
After a lot of searching we've found them - Macro 9000 and 9001 - I think 9001 will be the one John Brown modified and added (and changed parameter 240 to 6 in order to use)
donations gratefully accepted toward the next Denford booze up
Code: Select all
{Toolchanger macro paranoia version!03/07/93}
:9001
(RESET ALL FLAGS)
#1100=0
#1101=0
#1102=0
#1103=0
T#149
(CHECK FOR SAME TOOL NUMBER)
IF[#1004NE0]GOTO10
(MOVE TO HOME POSITION)
G91G28X0Y0Z0
(WAIT FOR TOOL CHANGE REQUEST)
WHILE[#1000EQ0]DO1
END1
(MOVE TO TOOL CHANGE POS)
G00Z-76.7
(SET FLAG TO SAY ARRIVED)
#1100=1
(WAIT FOR FLAG TO MOVE UP)
WHILE[#1001EQ0]DO1
END1
(MOVE HEAD HOME)
G28Z0
#1101=1
(WAIT FOR FLAG TO MOVE DOWN)
WHILE[#1002EQ0]DO1
END1
G00Z-76.7
#1102=1
(WAIT FOR TOOL CHANGE COMPLETE)
WHILE[#1003EQ0]DO1
END1
(SET RESET FLAG TO PLC)
#1103=1
(WAIT FOR ATCREQ TO GO LOW)
WHILE[#1000NE0]DO1
END1
#1100=0
#1101=0
#1102=0
#1103=0
N10M99
Code: Select all
{Triac centre.Program for toolchanger operation.Tydfil 30201B.03/07/93.}
:9000
(RESET ALL FLAGS)
#1100=0
#1101=0
#1102=0
#1103=0
(CALL UP THE ORIGINAL T CODE)
T#149
IF[#1004NE0]GOTO10
(READ ABSOLUTE/INCREMENTAL G CODE INTO VARIABLE)
#103=#4003
(READ INCH/METRIC G CODE INTO VARIABLE)
#106=#4006
G91G28X0Y0Z0
WHILE[#1000EQ0]DO1
#100=#1000
END1
G00Z-76.7
#1100=1
WHILE[#1001EQ0]DO1
END1
(MOVE HEAD HOME)
G28Z0
#1101=1
WHILE[#1002EQ0]DO1
END1
G00Z-76.7
#1102=1
WHILE[#1003EQ0]DO1
END1
#1103=1
WHILE[#1000NE0]DO1
END1
#1100=0
#1101=0
#1102=0
#1103=0
(RESET ABSOLUTE/INCREMENTAL TO ORIGINAL VALUE)
G#103
(RESET INCH/METRIC TO ORIGINAL VALUE)
G#106
N10M99
Many thanks. I will load the programs in the morning and let you know how I get on.
Success!!! Copied the files and uploaded to machine via Alphacam software. Reset the parameters 0010 and the PWE back to 0.
Many thanks for your efforts.
