Page 2 of 2
Re: Homing Problem on Triac
Posted: Fri 25 May , 2012 9:07 am
I have attached a copy of the wiring diagram
That .tif file wouldn't show through the Forum - I don't know how it was created but I'd recommend exporting or saving images to .JPG and keep them at about 1024x768 pixels. If you want more higher detail then .pdf is the way to go.
I've created a .jpg of your drawing which is only 70 Kb whereas the .tif was 2000 Kb (which makes a big difference to our limited server space)
Posted: Fri 25 May , 2012 13:44 pm
You may have a short inside the lube pump. Remove the lid from the pump & check the motor coil & that no wires are shorting to ground.
Posted: Mon 28 May , 2012 9:13 am
by benners
I have had the lube pump housing apart and can see nothing that looks out of the ordinary. I have disconnected the pump motor from the cover and again tried to M3 but the same thing occurs. Just thinking out loud - is that to be expected as there is nothing connected to the wires or is the issue with the motor and not something in between the motor and rack. Is the assumption that this expected behaviour correct?
Posted: Mon 28 May , 2012 9:26 am
If the motor has been disconnected and you still get a short/current drain then it could be a problem in the connector or a wire that's lost it's insulation.
Quickest way to prove that would be put a new wire from the SGR contact directly to the motor
Posted: Mon 28 May , 2012 12:09 pm
It may also be worth belling out the wire. Just to make sure it is the same wire.
