Triac year 2000 tool changer question
rasp
Post by rasp » Thu 28 Feb , 2008 19:14 pm
The tool changer on my Triac loads tool 6 when I ask for tool 1, how can I reset the tool positions so it loads the correct tool.
Is the current tool stored in a file somewhere so I can change it or do I move all the tool markers on the changer to match the position.
Or is it something else.
Thanks in advance.
Rasp
Triac whizz
Post by Triac whizz » Thu 28 Feb , 2008 23:19 pm
Off the top of my head with no docs in front of me
In MDI type in M25
this resets current holder to number 1 so move to number one first.
if it's not M25 it's M 20 something, if nobody chips in I'll find the book tomorro
www.la-coterie.com
Post by Martin » Fri 29 Feb , 2008 0:18 am
M27 (Reset Carousel to Pocket One).
This code is used to reset the carousel back to position one.
rasp
Post by rasp » Fri 29 Feb , 2008 12:21 pm
Thank you for your reply, I have tried the M27 and it looked as if it had not worked. When I powered up the machine today the tool number was correct. I can only assume you have to do a restart after the M27.
Rasp.
Triac whizz
Post by Triac whizz » Fri 29 Feb , 2008 12:54 pm
You have to manually shift the carousel to tool position 1 then M27 and it then thinks the current tool is number 1 - it doesn't actually move the carosel after entering M27 - oh did you press run after entering M27 in MDI?
you can test it out after by entering M6 T3 for example and the carousel will go to tool 3
(well at least thats what happens with a Fanuc version :roll: )
www.la-coterie.com
