Starmill dongle
stepheng
Hardware/Software: Starmill pc
Starmill dongle
Post by stepheng » Wed 15 Feb , 2012 14:07 pm
Hi, I have a Starmill PC, all is operating with VR Milling.
When I start Mill Cam design I get the log in window, you click on Administrator but I have no password, can I introduce a new password.
Or I have the original owners code to run program. Which ever I use the screen comes up Dongle not present.
I have three dongles non of which will work .
Any suggestions..
Re: Starmill dongle
Post by Martin » Wed 15 Feb , 2012 22:22 pm
What opperating system are you running from?
Try running "drights.exe" to check the dongles.
stepheng
Re: Starmill dongle
Post by stepheng » Mon 20 Feb , 2012 18:54 pm
Tried dright, it flicked open then closed, how do I get it to stay open. Went to properties and went through the menues and could not find any test or check systems.
Re: Starmill dongle
Post by Denford Admin » Tue 21 Feb , 2012 10:07 am
Open command prompt first (Start > Run and type "cmd" then OK)
Then type something like "c:\denford\drights.exe" into the command prompt and press enter
Type exit to close the command prompt
stepheng
Re: Starmill dongle
Post by stepheng » Tue 21 Feb , 2012 11:14 am
Hi, Have checked dongle through drights.exe, and it says it recognises Fanucm, fanucmd, mill cam designer, denford language.
and the dongle number as on the dongle.
So all appears to be recognised.
When I now click on mill cam design on the windows desk top I get Dongle not recognised, any suggestions.
Re: Starmill dongle
Post by Denford Admin » Tue 21 Feb , 2012 11:26 am
Dongle not found on XP machines
/viewtopic.php?f=2&t=16
CNC Tutor - Windows Software problem (includes dongle info)
viewtopic.php?t=2258
Old Technical Support Queries
viewtopic.php?f=9&t=2289
