Afternoon All
So my Denford 2600 Pro spindle has started sounding awful, sounds like it's cutting even when it is not touching the material, this sound goes on and off, and varying the spindle speed can help. I think the bearings could be on the way out but I can't seem to find much in the way of a replacement spindle or which bearings it needs if I strip and refurb it.
The door switch is also now starting to play up so will most likely override the door switch as I did on my 1000 pro so it thinks its always shut.
Any help with the spindle would be really appreciated.
Denford 2600 Pro Spindle
