Could you tell me orac cnc lathe bed ways dimensions?
mineunsik
Hardware/Software: cnc lathe and mill
Post by mineunsik » Tue 13 Jun , 2017 9:01 am
Hi i.m min from korea.
I need help.
Restoring old orac cnc.
tony millyard
Hardware/Software: Orac lathe with DIYCNC controller running with Mach3.
Wabeco milling machine with CNC4YOU controller running with Mach 3
Re: Could you tell me orac cnc lathe bed ways dimensions?
Post by tony millyard » Thu 15 Jun , 2017 10:50 am
I presume you have an Orac lathe already. so what dimensions do you need?
cheers
Tony
mineunsik
Post by mineunsik » Tue 07 Feb , 2023 14:16 pm
I just saw your comment.
The contact between the lower plate of the tailstock and the rail of the lathe body is not good, so the dimensions need to be modified, but the angle and size of the rail are unknown.
Can you tell me your email address?
Best Regards
Min
