Customer says ...............
Orac has been relocated in a different room and now gets the following problems
1. The tool offsets do not seem to be remembered correctly, it will work fine once the offsets have been set, but on restarting the Orac the offsets are not correct
2. The spindle will only run at 50RPM
Any ideas anyone ?
Offsets not been remembered
Re: Offsets not been remembered
I didn't think the Orac remembered tool offsets anyway
You can save and load them to micro tape though...
The low speed could be a loose or broken wire in the command to the spindle drive (ie it's enabled and running at minimum speed)
Hi, my Orac doesn't remember tool offsets if power turned off, I thought that was normal.
All other functions work OK.
