orac power supply
Bert
orac power supply
Post by Bert » Fri 04 Feb , 2011 23:21 pm
Hi to all
A couple of years ago I had good help from this forum in getting an orac up and running
I decided it would be nice to have the machine sitting lower on the bench so I striped out the base unit and cut of the lower section.
Oh boy what have I done,
I got carried away with the side cutters late one night
I have got the 63 volt suply for geckodrives
I need a 12 and 24 suply for auto turret
On previous instalation I had geckos mounted on circuit boards that slid into origional rack.and used a regulator fitted on to the each circuit board to lower a 24v supply on the rack to 5volts for the gecko comm terminal this worked well but as I striped out every thing I now need to put the other smaller transformer back into play to get back the 12 and 24 v
I have powered up the smaller transformer and reconected it to the origional board with the diodes and capaciters and had a check out with the meter and found what wires I need for the 12- 24v.
The bit I can't get my head round is how does the gecko get its return wire if it needs own at all
Bert
Re: orac power supply
Post by Bert » Sun 06 Feb , 2011 22:55 pm
Ok so i have had a look around at what others have done.
I am going to do away with regulators and get or make a +5v supply that will go to the BOB and give each gecko a new supply from the +5v that will go into BOB
The only thing I have not found out yet is what amp rating does the BOB and Geckodrive need for the +5v
Found referance to using a +5 supply from pc tower but some say it is a bad idea to use pc for it
any help would be nice
cheers bert
Post by Denford Admin » Mon 07 Feb , 2011 10:34 am
This might help:
https://compreviews.about.com/od/cases/a/PSUWattage.htm
I can't see why a PC PSU wouldn't work ok - it's worth trying for such little money (2nd hand)
Bert
Post by Bert » Mon 07 Feb , 2011 11:56 am
I thought I read someware that a pc power supply would need to be modified if using it as a standalone supply
I have got a 12v 3amp power supply unit off a disused external hard drive that i might use as both stepper boards and the bob have been fitted with 5volt regulators or,
I could modify the power supply and reduce the output and do away with the other regulators
still a bit worried about possibly having to many amps
bert
ps is there a spell check on this site
Post by Denford Admin » Mon 07 Feb , 2011 12:12 pm
You may have to short a couple of pins to make the PSU power up and the unit may not run without a load, ie, something connected to it - hence the load resistor fitted in these links:
https://web2.murraystate.edu/andy.batts/ ... SUPPLY.HTM
https://www.smpspowersupply.com/connectors-pinouts.html
There is no spell check in this site, but you can always try an online spellchecker like this first: https://www.spellcheck.co.uk/
Can you have too many amps ?
It's better to be over-rated, than under... if you're worried about it burning things up, then limit the current with the correct size fuse or circuit breaker.
