HELP CONNECTING VR TURNING TO NOVATURN NS
Dodds
Hardware/Software: Novamill
Mach3
Post by Dodds » Wed 02 Aug , 2023 23:45 pm
Please can anybody help me to connect VR Turning to my Novaturn NS.
I recently acquired a lovely Novaturn NS. I did have this working from my pc using vr Turning to test it out. It worked! although it wasn't straight forward to connect . (Possibly because I was using a serial to USB adapter? However I did have it working with this.)
Using this adaptor I found it a bit unreliable. (Can't be sure this adaptor was to blame!!?? ) It would run a test program but suddenly stop halfway through the program. When I changed to a serial cable 25/9 pin it was reliable in tests.
Now I have set it up in its permanent position in my workshop and try to connect it using vr Turning via the 9/25 pin cable, it will not connect.
Easy upgrader 2 connects and says the machine is up to date.
However VR will not connect. The cursor just sits there spinning and I have to crash the program.
Here are some photos that show settings etc. Can anybody suggest what I might be doing wrong?
Mitch
Re: HELP CONNECTING VR TURNING TO NOVATURN NS
Post by Mitch » Thu 03 Aug , 2023 11:54 am
HI,
The only thing I can see software size that is different from default is the Baud rate, which should be set to 57600. maybe this will help.
Mitch
Dodds
Mach3
Post by Dodds » Thu 03 Aug , 2023 12:39 pm
Hi Mitch, thank you for replying to my post. I changed it to 19200 from 57600!
I thought that the figure had to be 19200? I read that on the forum in another post. Is there a different baud rate depending on the machine or cable used?? I am not a computer man so don't really understand this type of stuff!
When I get home tonight I will try 57600 and let you know.
Thanks again for your help.
David.
Dodds
Mach3
Post by Dodds » Thu 03 Aug , 2023 22:47 pm
Hi Mitch, I changed the baud rate to 57600 and it still would not connect. I restarted the pc and still no luck.
However I decided to reinstall vr Turning and using 57600 it now connects!! So great news. Many thanks for taking the time to suggest the different baud rate.
For anyone else reading this who are in the same position as I was. Here are the settings that work for my Novaturn NS (green display) with rs232 cable 25/9 pin connection.
OK!
I do have a second novaturn ns with USB connection orange display and these are the settings that work for this.
David.
Mitch
Post by Mitch » Fri 04 Aug , 2023 9:35 am
Hi David,
Really the machine should have connected with the lower Baud rate (its just a connection speed as such), it was the only difference I could see in the setup. but from what you found it must have been an issue in the installation.
Your other machine with the USB connection will not use the set Baud rate as the driver will manage the connection speed.
if you can find one of the newer USB cards online or from a another used machine or control panel you can upgrade your older machine to the USB card.
Mitch
Post by Steve » Fri 04 Aug , 2023 13:20 pm
The serial cable you are using does not look to be the correct one. It should be a Black Lindy cable and is not an off the shelf serial cable.
The cable should be a BI01812GG viewtopic.php?f=54&t=765&p=23012&hilit= ... 232#p23012
viewtopic.php?f=54&t=2351&hilit=BI01812GG
I dont know how it ends up connecting through easy upgrader though.
The links above should be good to sheck the cable aganst.
Dodds
Mach3
Post by Dodds » Fri 04 Aug , 2023 19:17 pm
Hi David,
Mitch
Hi Mitch, all good points! I am not a technical person when it comes to electronics and that's why I am on here looking for answers. I just want to make things on my lathe 😁
Is it just me? But this is not the first time I have had connection problems. In the past I have solved them trial and error without really knowing how I have done it!
I might well upgrade to USB for the second machine now I have seen how much better it is. I didn't tell the whole truth! I actually have 3 Novaturns. Lol. The third would definitely benefit from the USB upgrade as it is Denstep. Does anyone else love these little machines? 😁
All the best. 👍
Dodds
Mach3
Post by Dodds » Fri 04 Aug , 2023 19:30 pm
Hi Steve thank you for your comments. I was aware that the 25/9 pin cable is wired different to standard. My brother has helped me on this. He has made me 2 cables. Wired the correct way. I also have one of the black lindy cables you mention. However I have a fourth, off the shelf cable and that works as well. So must be a fluke?
Great that you guys share your knowledge 👍
Many thanks..
David.
Dodds
Mach3
Post by Dodds » Fri 04 Aug , 2023 19:36 pm
Regarding the "off the shelf" cable that works. You tech guys might know if this Null modem might mean anything?
